I guess I will never be a puristFunkalicousgroove wrote:And we all know that guitarists NEVER obsess over minutia!glasman wrote:that is about the same, a .022uf MPP works nice there. I am sure the green chiclet mylars would also sound good.Funkalicousgroove wrote:I ended up with .02150, the .027 was a bit gnarly sounding.
I actually preferred the subtle 500pf mica, but I know that the fellow getting this one has a real Dumbleator II and will expect that HUGE bright cap sound.
But, in reaility, WHO really uses the bright cap on the send side. (unless you are feeding it to a PA or mixer off stage).
Gary
Stereo Loop-a-lator
- glasman
Re: Stereo Loop-a-lator
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
- Funkalicousgroove
I feel ya on the smaller rack, I'm having some made up 10" deep to fit both mono and stereo units.
BTW, you might want to check the USPTO on using "Matchbox" pretty sure Matchless has a trademark on that one, just to save you the grief and aggrivation!
- glasman
Are you thinking of the Hotbox.Funkalicousgroove wrote:I feel ya on the smaller rack, I'm having some made up 10" deep to fit both mono and stereo units.
I did a search and did not find the two related, but USPTO TESS is a POS to find anything.
Gary
www.glaswerks.com
www.glaswerks.com
- Funkalicousgroove
Looks like It's Rolls, they make an impedance buffer called a matchbox- I was thinking of the hot box, you're right about that-
- glasman
Funny, I have a Rolls Matchox sitting on my recording console.Funkalicousgroove wrote:Looks like It's Rolls, they make an impedance buffer called a matchbox- I was thinking of the hot box, you're right about that-
I actually took the name from the old E.F. Johnson antenna tuner called "The Matchbox".
www.glaswerks.com
www.glaswerks.com
- Funkalicousgroove
In these tight times I wouldn't give anyone a reason to ask you for $$ if ya know what I mean-
- glasman
I know what you mean.
My new amp line
Garys Amp 1
Garys Amp 2
My new amp line
Garys Amp 1
Garys Amp 2
www.glaswerks.com
www.glaswerks.com
- Funkalicousgroove
USPTO TESS gives you registered names but if someone can show prior usage registration doesn't matter. These day if it doesn't show up in USPTO TESS or on a google search you are probably good to go.
www.RedPlateAmps.com
I always thought the PERCOLATOR would be a cool name..LOL!!!
Tony VVT
Tony VVT
- Funkalicousgroove
isn't that one of those old school coffee makers that give you a cup of joe full of grounds?
Yup!!! When you get to the last cup you run the risk of swollowing some grounds.. It did make a smooth cup a Joe!!!
Tony VVT
Tony VVT
- Funkalicousgroove
Funk
You could stick one of these on top.. Figure out some way to have some brown liquid bouncing around in the glass bulb and light it up..
Dat's funny right dare.. I don't care who ya are!!!
Tony..VVT
Tony..VVT
- Funkalicousgroove
Perhaps utilizing snow globe technology!
