Thanks....
The buss wire is supported on some lugs. It is a nice way to do it but getting the correct lugs for the job appears to be the biggest hurdle. If you look at some of the builds from Allyn and others, you will see the same technique used and I believe it was a KF trick he used although I 'm not suer where. Unfortunately, Ampwares is the only source I know of and you still have to do some work on them to get the buss wire to fit if you use the 2w pots.
I just got some NOS tubes for it now so I should be back in there soon to set that up and hopefully get some clips done.
Express build finished
