That's been my experience so far, but not even close with this one. With the 12AT7 I have 330 on the CF plate, 160 on the CC plate, 64V on the CF cathodeheisthl wrote:If you using 250KA pots unity is approx. noon and noon on the knobs. Like Gary said the cathode should be at 30 volts with the new values
Understanding the cathode follower (D-ulator)
Re: Understanding the cathode follower (D-ulator)
- glasman
Bob, what is the order of your string?
The real deal used the the following order. I have seen a lot of confusion on this over the years.
Gil and I have discussed this many times as well. I am still not a big fan of the 100K series resistor. The time constant on the second stage filter is measured in days
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
- glasman
Actually it takes just under 17 seconds for the second stage to come to max voltage.
www.glaswerks.com
www.glaswerks.com
Because it is a 12AT7.
Bob-I wrote:That's been my experience so far, but not even close with this one. With the 12AT7 I have 330 on the CF plate, 160 on the CC plate, 64V on the CF cathodeheisthl wrote:If you using 250KA pots unity is approx. noon and noon on the knobs. Like Gary said the cathode should be at 30 volts with the new valuesand 2.4 on the CC cathode. I'm still at about 40% on both send and return for unity.
- glasman
Scott is correct, to use an AT7 you would have to juggle all of the values.
Bias points are different as are the plate loads for the recovery amp.
There "could" be a benefit as the AT7 has a broader frequency response than the 12AX7.
www.glaswerks.com
www.glaswerks.com
String? What string?glasman wrote:Bob, what is the order of your string?
I'm using a single node off the screen supply. I did this on another amp this way and it's a very effective loop, in fact the loop alone adds harmonic content to the tone even without anything in the loop, but the loop sounds great with a cheepy Alesis Midiverb.
I put a 12AT7 in my other amp accidently, it was in the wrong box. I liked the way it sounded.glasman wrote:Scott is correct, to use an AT7 you would have to juggle all of the values.
Especally on the high end with a delay.There "could" be a benefit as the AT7 has a broader frequency response than the 12AX7.
Cool, I need to get back on my bench and try this -have you guys also increased the cath bias resistor, or does the increased tail suffice?
I've had good luck using a 12ax7 and this dropping string:
www.RedPlateAmps.com
I'll investigate this, thanks. Does increasing the 10k tail generally suffice to
rebias the cf stage, or have you found that the cathode resistor also needs to be increased?
- glasman
Increasing the tail would probably do the trick, but I have not tried it. I would say increasing the cathode is still a good idea as it raises the potential difference between the cathode and grid a little bit.butwhatif wrote:I'll investigate this, thanks. Does increasing the 10k tail generally suffice to
www.glaswerks.com
www.glaswerks.com
I took a look at my internal dlator, and was able to fix most of the one sided clipping , here's a scope trace of the before signal out of the CF and by raising the cat bias up to 32 volts I was able to get most of the clipping out. Actually, it had to go to 60-70vdc to pass a very hi clean sine wave, but stopped at 32v as that is where the output section clips. Also, here is a trace of an OD waveform with a 1khz sig in. One thing I realized is the importance of the .05 blocking cap on the input grid of the CF stage. If that's not there--and one might not put it in, the CF stage will get rebiased by an amp that is plugged into it--like an OD master from a clone amp.
- glasman
Very good info and you took the exact steps I took when I was searching for the problem.
Gary
Gary
www.glaswerks.com
www.glaswerks.com
That's exactly what mine looked like. I put in 1.8k/27k as suggested and my cathode is at 62V. It's completley symetrical now up to the point where the clean stages clip. I hadn't thought about the output clipping but that's a good point.butwhatif wrote:I took a look at my internal dlator, and was able to fix most of the one sided clipping , here's a scope trace of the before signal out of the CF and by raising the cat bias up to 32 volts I was able to get most of the clipping out. Actually, it had to go to 60-70vdc to pass a very hi clean sine wave, but stopped at 32v as that is where the output section clips.
What values did you end up with to get 32V?
I used 2.2k/30K, but my amp is a mod, (Mesa Mk III) not a build- My power is off the main string also, but modified, I remember around 310v on the plate of the CF.
