Reverb mods made
MarkB
Re: Reverb mods made
Post by MarkB »
Bob-I wrote:
MarkB wrote:Bob
Have you seen the TUT reverb? K. O'C. talks about ways of dealing with reverb noise.
No I haven't. I'd like to :wink:
Email addy?
Bob-I
Post by Bob-I »
MarkB wrote:
Bob-I wrote:
MarkB wrote:Bob
Email addy?
bob-ingram@patmedia.net
Thx
glasman
Post by glasman »
Bob-I wrote:Actually, I decided to try reducing the gain first. The 2 extra components, the coupling cap and series resistor look good, but it would require I change my layout. I'll try lowering the first return load resistor to 22K, then the second to maybe 47K. I believe that should address the reverb balance.
Bob, I was going over that lack of coupling cap and I think there could be some serious potential problems.
Looking at the plate of the second recovery amp I am guessing that there is somewhere around 190 volts on the plate. If you follow that back in the circuit to the relay it is going to put 160+ volts on the Clean Master Pot and OD level pots. If you turn the master or OD to zero, that 160+ is going straight to ground through the pot.
Put the amp in Clean D mode and measure the DC voltage on the wiper. Also try it in OD mode and measure the OD level wiper to ground, I bet you will see a pretty high voltage there, of course this is just my 2 cents.
Gary
About 5 miles south of I-94
www.glaswerks.com
Bob-I
Post by Bob-I »
Gary
Yes, it's over 180V, that explains the scratch on the pot. Coupling cap going in.... thx.
glasman
Post by glasman »
No problem.
Gary
www.glaswerks.com
Bob-I
Post by Bob-I »
In another thread the "too much reverb" issue came up. Gary suggested using a dwell control or voltage divider on the input of the driver amp.
I tried several things today. First a 470k / 470k divider which only dropped the reverb a little, so instead of having the reverb control on 1, I could put it to 1.5 :lol:
Next I changed the divider to 220k/820k, better but still not exactly right.
Finally I took a 500k mini pot and soldered it in. Yes the load should be 1M but I don't have a 1M pot small enough. This seems to be the trick, a dwell control is necessary. I'll source out a small 1M pot but for now the 500k is staying in.
