Had to do the cap stack at "an angle"
 Otherwise the caps on top of each other, would have been higher than the base plate. Strange!!
Anyway, nearly there.
Couldn't use the earth buss attachments.(almost like a washer with a "leg"). Will post a pic. Firstly, they do not work with the PEC pots. The pots are thicker than average. Secondly, if I did use them, I would not have enough clearance on the pot thread for a wooden face plate. Hope this makes sense!
I will have to solder copper earth buss to the back of the pots. Not my best choice.
I would like to separate the power supply node earths.
1. Power tubes and PI (3 bottom caps) at one spot (near PS caps?)
2. Preamp B+3, 4 and 5 (top 3 caps) at one spot (where?). Maybe at input jack?
3. CT's and PT Earth at one spot (as per pic)
Any input welcome.
