1972 Fender Bandmaster Reverb AA270 TFL 5005D
Re: 1972 Fender Bandmaster Reverb AA270 TFL 5005D
Cleaned up the cab. Utah speakers, date codes say 1968. One cone totally torn, so I set those aside. Huge cabinet, man. 39" x 29" x 11". Pine sides, particle-board baffle and back.
- Leo_Gnardo
Had my nose in a '57 Silvertone all day, then typing up invoices, then the feedbag.xtian wrote: Hoping to hear from Leo or someone on building an LED-based opto bug replacement.
I use a superbrite orange or yellow LED (Mouser, about a buck) and photocell sold as a Morley replacement by CE/Antique. Just put 'em in an inch of black HST. Long LED lead goes to the 100K & bobsyeruncle. I used to worry "high voltage" but these have lasted years so far, no breakdowns & no other mods.
Fender bugs, aging as they do, often the photocell becomes weak or one of the leads breaks loose. At the other end, the neon darkens with age, sometimes becomes weak, and often injects a tick into the audio.
Awesome. Imma do it.
- norburybrook
I have exactly the same amp, mine's 1970 , has 'Torrez' hand written on the chassis inside.
Re-capping it is what whet my appetite for amps and got me started on this path a few years ago. It's a great amp, classic fender pe amp, spring verb and Trem . MY original trem isn't to bad actually. Moving a few wires solved the ticking.
The lead dress inside is a complete rats nest but it's quiet as a mouse ands sounds perfect.
Marcus
Marcus
I put a pair of Jensen C8R speakers in the valence. Sounds nice! Makes a cool, portable practice amp! This requires moving the reverb tank to the floor. Still works well, no hum from transformers.
Next, I'm recapping. You can see in the photo that the old caps are starting to breach. But notice a couple of weird things! The middle 20uF cap is installed correctly, but its cardboard jacket is labeled with incorrect polarity!
Also, notice that the dropping string resistors are 2K2, 10K. Most similar Fender circuits use 1K, 4K7. I think I'll go back to spec. I was thinking the amp sounded a bit under powered...though that could be the tired caps.
This is quite the find! Looking at the doghouse caps, Mallory (235) 7145 makes them November 1971, so, yes, 1972 is probably right.xtian wrote:...though inside of chassis is stamped "RICHARD HAND, JAN 4, 1972." So, do we call this a 1972?
Thanks, Phil. I got to dime it for a bit today--very much louder and punchier than before new caps and 1K/4K7 dropping resistors. Measured 35 watts clean, using Russian 6P3S power tubes.
nice score....
scooter_trasher
