Check this out......
redshark
Re: Check this out......
Post by redshark »
I just opened up this amp. I will post some pics. The only wood board is the one with power caps. It has 3 boards for 3 diferent preamp sections. Input, overdrive and phase inverter. The OD trimmer is glued. Seems to me they liked that setting. The amp is not gooped so all can be seen. Great sounding amp here!!
Aaron
Post by Aaron »
:D :D :D :D :D
tictac
Post by tictac »
FYI: The box with the transformer is likely a 600:600 line out. I'm getting ready to put a similar line out in an amp I'm building. Jensen has a nice drawing of this...
TT
Duble
Post by Duble »
redshark wrote:I just opened up this amp. I will post some pics. The only wood board is the one with power caps. It has 3 boards for 3 diferent preamp sections. Input, overdrive and phase inverter. The OD trimmer is glued. Seems to me they liked that setting. The amp is not gooped so all can be seen. Great sounding amp here!!
This is very cool, can't wait to see the pics, this amp is unique.
redshark
Post by redshark »
Quick question.....
Does anybody has the part number of the FET input jack?
Thanks!!
I forget what the original part # is but this jack is supposed to be a higher quality of the same type.
Calrad 30-385
ic-racer
Post by ic-racer »
I have used a Kobiconn 161-0083-E also.
redshark
Post by redshark »
Thanks guys!!
redshark
Post by redshark »
Second question....the guitar cable going into the FET can be a regular guitar cable or a stereo cable?
Aaron
Post by Aaron »
Ooooooooo, an ODS with with a PCB board. Very cool!
Looking forward to the rest of the pics :D
Aaron
Charlie Wilson
Post by Charlie Wilson »
redshark wrote:Second question....the guitar cable going into the FET can be a regular guitar cable or a stereo cable?
Regular cable.
CW
Pics please? :D
ayan
Post by ayan »
redshark wrote:Quick question.....
Thanks!!
They are "isolated make" jacks and the correct part number(s) is(are):
Enclosed Version, Nylon Bushing (Used by Dumble)
Switchcraft N113X
Open Frame Version, Metal Bushing (Common Replacement)
Switchcraft 13
Both available from Mouser by adding "502-" in front of the P/N
Gil
redshark
Post by redshark »
Both jacks, the Kobiconn and the Calrad don't look like the one in the picture. Any other input jack options?
Charlie Wilson
Hello, I think you just got all of the options. I am curious though, are you going to replace the one in the Dumble and if so, why?
CW
