IS that 8-9 oclock? if so what clock setting would be OFF for your controls?mat wrote: I put the drive level usually at 8 or 9. I seem to get best results with my nonHRM and the new HRM in that way. The drive will be anywhere between 5 to 9Yes, You are right the d-lator knobs affects a great deal to the sound also. Do You try to put them at unity gain or boost the signal a bit ?
Just for reference, my control knobs are installed so that 6 oclock is off. I normally run drive at about 9 oclock and level at about 12 oclock. I have run drive up to 12oclock if I really want a lot of clipping for certain applications. The gain settings before the drive control (input device, vol., OD trim,) will determine how high the drive control gets set. With the Strat, I run my vol at about 1 oclock and my trim almost all the way up. The dlator I set to put as hot a signal as the GT-3 will take without clipping, but sometimes I back it down a bit because the Send control ends up being sort of a master volume. other times I will use the return control as the master. Just depends on the sound I want. Overall though I would say it is less than unity gain. If I switch the d'lator out of circuit, I have to back down the OD lev. to compensate or it will be too loud. It just works out that way for the sound I like. Lots of room to experiment here.
Yea, I am going to try HB's soon although I will always keep exploring with SC guitars. i feel like if an amp can sound good with a stock Strat, it will sound good with about anything.mat wrote: Thanks for the dry clip also. I like it alot! Do You have a HB guitar ? I was a strat/tele/singlecoil -only fan for a long time but the dumbles turned me to HB guitars. I still love the sound of strat to dumble tho', it is just different thing than HB+dumble style amp.
To that end, I ordered a Reverend RoundHouse HB last month and it should be here in the next few weeks. I just feel like my amp wants humbuckers so I will explore that a bit. I am not done tweaking this amp for my Strat though (is anyone done tweaking?) I feel like it could use about 2-3 db of boost centered on 1.25K when playing leads. Also, I am thinking about re-connecting my choke. When i play double-stops it is getting some "beating" going on. Not sure what is causing this, but my Twin and even my Tone King did the same thing, though to a lesser extent. I think I just need a little more filtering although It may result in some loss of that nice compression you get without the choke.
Now that I have a HB guitar on the way, I am having the same thoughts!mat wrote: My dream (after I get my HRM ready) is to have a switch in the HRM to choose between optimal SC sound and optimal HB sound. More switches....![]()
