Trainwreck Songbird 30
Re: Trainwreck Songbird 30
Adam,
Yes very descriptive indeed. :) Ken's sister Mona told me it was a great sounding amp, hopefully I can make it happen.
Perhaps octal version too :wink:
Turbojunkie
Post by Turbojunkie »
I am soooo curious about experimenting with octal preamps, as I have zero experience with them....in all my travels, I haven't even seen an octal-pre guitar amplifier, let alone play one. With others describing them as fat and chimey, my interest is piqued!
Mark, on the transformer set...just browsed at the specs on the Edcor site, it looks like a standard set of Rocket transformers would be fine? I ask because I have a set of Allyn's Pacific versions on the shelf right now that need a home soon, and the Songwriter 30 soundclips on Komet's site are starting to make me drool!:lol:
Best wishes to you and your family,
Adam
From what I can tell the Rocket transformer specs would work very well.
Updates on the wiring.
Colossal
Post by Colossal »
I spy a polystyrene! Tha cathode bypass cap on the output tubes isn't going anywhere.
Looks great Mark!
My work is getting poor I better have some of our TAG members with free time wire up some builds for me. :)
RJ Guitars
Post by RJ Guitars »
Nice job Mark! Great to see you building amps and sharing the experience with us.
Isn't the Song Writer just the "other" (non-top boost) channel from a Vox AC-30? If I have that correct then the Rocket iron should be ideal? Does anybody know?
http://www.rjguitars.net
Bob, yeah I was going to just order some iron from you but that was when you were having troubles so I got some from Edcor instead.
A470 4k OT will work very nice and keep voltage low I thing on the PT with 280-0-280.
I've had this stuff sitting around for a while and finally decided enough is enough get going on it.
Gaz
Post by Gaz »
Not like you're gonna zap yourself, but good job on not wiring the B+ backwards like Komet did. Oops.
DocJames
Post by DocJames »
I'll be keeping a close eye on this thread! It's great to see someone tackling this.
Yes fixed NFB off 16 ohm tap.
4k7/220k
beasleybodyshop
Post by beasleybodyshop »
Mark, clever use of a binder clip. Going to have to steal that one!
Yeah I'm full of tricks. :lol:
I'm thinking of going with wireless output too. :wink:
Looks good!
So what's different about the tonestack baxandall??
The treble almost looks like a cut control?
Treble control is definitely a treble cut control called tone control on a lot of amps that use this.
Bass volume is unusual but not unlike what some have used on 18w Marshall variants on 18watt.com
