Well, I did some re-wiring and swapping out of resistors today and noticed that the plate voltage on V1a was about 200v...way higher than the 150ish that it should have been. I replaced that resistor with another 220k and now the voltage is back towards what I'd consider normal. That helped a LITTLE bit with the hiss, but the crackly poppy stuff is now gone. Good deal.
I also replaced the 56k cathode follower resistor with another one of slightly higher value (59k-ish) and that did nothing to remove the hiss.
There is no sign of excessive DC on the coupling caps.
I even replaced other plate resistors (pretty much all resistors in general...) and nothing really changed.
The grounds all seem to be good. Voltages are where they should be. I'm beginning to think that this carbon-comp bashing is hyped up more than it should be, and that issues attributed to carbon comp usage may very well be a result of poor build quality first, then a possible noisy resistor later...so I'm not going to go buy a bunch of carbon or metal film resistors and totally re-build my amp. I've played pleeeeeenty of amps built with carbon comps, and they've been plenty quiet...even high-gain ones, so I'm inclined to think the issues is unrelated to component type and more related to build quality/layout.
To be honest, I'm not sure if this hiss issue is really even an "issue" anymore...that is, maybe this is just the way this circuit is supposed to run... I have a similar amp to compare with mine, but no two are exactly alike so perhaps it is unfair of me to expect this build to be what another build is.
Maybe it is an issue with wire runs? Maybe it is an issue with layout? Maybe maybe maybe.... Anyway, I appreciate everyone's help, but I'm getting weary of trying to figure out this thing and am going to go do some reading on preamp hiss and see what I learn. Who knows...
The amp does sound very nice, though...
Thanks again for your help...
