I was told to use the "rules of 3".
Three coats a day, for three days.
A coat is defined as around three passes over the body.
Start with a light coat, next coat a little wetter and the last coat wet.
But not so wet it runs.
That is one coat.
Then let it dry for an hour or so, then apply another "coat".
I usually don't spray lacquer unless the humidity is below 50%.
If you spray during high humidity you will get blushing, which is a
white haze in the finish.
It is water that is trapped in the lacquer.
You can use blush eraser or just stop and spray again when the humidity
 is lower and the blushing will go away.
I'm talking nitrocellulose lacquer here.
And that rule is basically for the clear coat.
A mistake many make, is putting too much color coat on.
You only need enough color to completely cover the body.
So three or four passes to get an even coverage is all that is needed.
And you don't really need to sand the color coats or any coats unless there
is a big run, drip or bug in the finish.
Nitro lacquer is unique in the way the next coat melts into the last coat.
So you don't need to sand in between unless there is a defect.
So after your 9-12 coats of clear are on, let it hang for at least three weeks if not four.
If you don't, the finish will not be hard enough to wet sand and polish.
The reason for the 9-12 coats is when you wet sand and polish, you are in effect
removing at least 1/4 if not 1/3 of the material sprayed on.
So it even though that sounds like a lot, it shrinks to a paper thin coating.
If you don't apply enough clear lacquer, you will be sanding into the color coat before
you know it and that's not good.
