Amplifier Power Regulator or Voltage Regulator question
Fender Amp Discussion
rp
Re: Amplifier Power Regulator or Voltage Regulator question
Post by rp »
Reeltarded wrote:They look like this and they are 10 amp rated. The meter is out to lunch or never works.
http://www.mcmelectronics.com/product/72-110
$70 20 years ago when I got mine from there, alas no more.
And I still think bucking transformer, as it's cheap, much lighter, and if a combo you can bolt it out of the way into the cab bottom.
hahah I bought 6 just about 3 years ago for $69 each, shipped!
fltundra
Post by fltundra »
http://www.apc.com/resource/include/tec ... sku=le1200
Works like a charm with my vintage Hiwatt!
Can't go wrong for less then 50 bucks.
Toppscore
Post by Toppscore »
Thanks, guys.
I have 1950s & 1960s vintage Fender amps
and will try to get something more reliable
than low-end products. Several are in the $200-$300
range with manual variable voltage regulation and
with good meters to see what output is actually
going into an amp's chassis.
Might even get a thirty pound one for a bit more
to permanently sit in my music room for all my amps
and electronic equipment.
Man, one cap job or a set of replaced tubes will pay for good variacs.
Toppscore 8)
Fan of Fender Trainwreck Dumble
