1965 Pro Reverb: Driving me crazy!!!
Roe
Re: 1965 Pro Reverb: Driving me crazy!!!
Post by Roe »
Structo wrote:The standby switch also me be suspect as this type of switch doesn't really like to switch high voltage DC current.
What I have done on my Dumble amps is add a .01uF 1Kv ceramic disc across the standby switch.
The only problem with the resistor across the switch is that the amp will not be muted all the way when switched to standby.
should be muted with a 220+k resistor
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Thanks for clarifying that.
I believe I saw a 100K used before and the description said it wouldn't mute it all the way.
