I understand that tone stacks have nothing to do with power. However, the early generation Dumbles seem to all be fifty watters, while later generation all seem to be 100 watts. I'm trying to understand when someone says 'X' generation how that relates to the power amp and the power supply filtering. For example, what generation introduced the "precision" power supply?stevlech wrote:
The tonestacks are the EQ circuits and have nothing to do with output power.
2nd generation has a 100k slope resistor, caps are 510pf/.01uf/.1uf
and 500k linear/250kAudio/1M audio pots
3rd generation is similar but with a 250k Audio treble pot
Classic tonestack has 100k slope, 330pf/.047/.1 uf caps
250k Audio/100k Linear/250k Audio pots
Skyliner has 150k slope, 2200-500pf/.01/.1 uf caps
250k Linear/250k Audio/500k Audio pots
There is more to it and there are variations, but these values are common amongst several known amps.
I hope this helps.
Did Dumble ever build a 2nd gen with a 100 watt power amp?
