My #102 Build.
amplifiednation
Re: My #102 Build.
Post by amplifiednation »
I ditched the 68pf too...I think 102 sounds great!!
Amplified Nation
www.amplifiednation.com
@ampnation
jazzyjoepass
Re: My #102 Build.
Post by jazzyjoepass »
dcribbs1412 wrote:Congrats jazzyjoepass
great looking build...
what speakers are you using?
Darin
I hardly play anymore, but just got into the amp building bug recently. I'm just running through a Celestion in an old Line6 Spider, but already things look really good. I can hear how it sounds through some greenbacks.
jazzyjoepass
Re: My #102 Build.
ic-racer wrote:
jazzyjoepass wrote: Funk's chassis that I bought many moons ago and finally came round to fixing it up..
I thought that chassis looked familiar. I just completed my long-term build on a Funk chassis.
You did a good job.
Any pics of yours then ???
jazzyjoepass
Re: My #102 Build.
amplifiednation wrote:I ditched the 68pf too...I think 102 sounds great!!
Yes !!! I ditched the 68pF and the tone network on the Preamp Out/Power IN.
Things really sound fantastic and I notice most schematics don't have that, so why the 68pF on RF's ???
erwin_ve
Re: My #102 Build.
Post by erwin_ve »
For use with a dumblelator. 68pF sounds terrible without a dumblelator.
bluesfendermanblues
Re: My #102 Build.
Post by bluesfendermanblues »
I have the 68p in my 102 clone, which is always used together with a D_lator (with minimix II for paralleling effects)
Sounds great and the 68p turns the master volume into a kind om master fat control. on 9 oclock the bottom end is reduced a bit an on 12 its much fatter.
dobbhill
Re: My #102 Build.
Post by dobbhill »
My understanding is that the 68pf is to compensate for cable losses when connecting the D'lator. Am I correct?
2cents.....
D
There are no stupid questions, just stupid people.......
ic-racer
Re: My #102 Build.
Post by ic-racer »
You did a good job.
[IMG:640:480]http://img.photobucket.com/albums/v670/ ... emorex.jpg[/img]
[IMG:640:480]http://img.photobucket.com/albums/v670/ ... CF5939.jpg[/img]
[IMG:640:480]http://img.photobucket.com/albums/v670/ ... CF5904.jpg[/img]
dcribbs1412
Re: My #102 Build.
Post by dcribbs1412 »
ic-racer
what brand are the blue MF in your build?
Darin
bluesfendermanblues
Re: My #102 Build.
dobbhill wrote:My understanding is that the 68pf is to compensate for cable losses when connecting the D'lator. Am I correct?
2cents.....
D
yes think so, but I've learned long ago from user Dogears, that you have to regard #102 + dumbleator + cables as a "system".
And the 68p is part of that system.
jazzyjoepass
Re: My #102 Build.
2cents.....
D
A bypass cap on the master volume would seem like the wrong place to compensate for cable losses.
Without getting into the maths, the cable losses are pretty constant regardless of the volume played, but the compensated highs with the bypass cap is variable with respect to the master volume.
Anyone can chime on this ???
jazzyjoepass
Re: My #102 Build.
ic-racer wrote:
jazzyjoepass wrote:
ic-racer wrote: I thought that chassis looked familiar. I just completed my long-term build on a Funk chassis.
You did a good job.
Nice !!! And two of them !!! Wonder how many of these chassis with the "D" labels are circulated :)
erwin_ve
Re: My #102 Build.
Post by erwin_ve »
2cents.....
D
The master on the amp is a set and forget thing(for me standard at noon) The real mastervolume is the last stage of the dumblelator.
ic-racer
Re: My #102 Build.
Post by ic-racer »
dcribbs1412 wrote:ic-racer
Darin
Chinese from ebay. One watt.
talbany
Re: My #102 Build.
Post by talbany »
In my travels it's best to use the bright cap before the D-lator ..Another words brighten the tone then smooth it and kill some highs using the Pf rating of the cables with the loop rather than the other way around.. With the loop attached it's a system..FWIW...With the loop in I set my master vol (on the amp) at 7, you want to drive the follower in the loop..:D
