I agree 100% with you and yes there are numerous things that you can do to that amp design. However, the more things you alter the further you get from being a true Wreck, which is my point. How much can you change on that amp without losing the “wreck sound” Yes you can change the OT and PT, increase the voltage on it so it can work better with those EL34s, but you know that will change things…unklmickey wrote:there are actually quite a few.pureoldsound wrote: ...I am not a pro but it seems that there are just a few things without changing the design to much that you can do.....
the size of bypass caps in relation to cathode resistors affects LF rolloff.
the size of coupling caps (HF rolloff)
where you have more or less gain, affects where in the chain distortion first appears, as do biasing closer to center, or closer to saturation in a particular stage.
the size of a bright cap (if at all).
NFB (if used).
the values in the tone-stack will affect frequency, amount of boost/cut, and the shape of the response curve at "neutral" settings.
so far, we're mostly talking about component values in the same circuit.
we haven't even mentioned the choice of iron or tubes yet.
[cheers,
unk
My point is Ken made the design. To his ears it got what he wanted out of the amp. Yes there are always complaint too bright, not enough low, too much gain, I need more headroom, too loud…..But there is little room to tweak without changing it too much, maybe increase the value of a resistor, or decrease it here and there. Major part changes, increasing voltages or decreasing IMHO compromised the sound. So my take is minor tweaks may have occur…If you wanted something different I think he might have directed you to someone else…..
