Norm, What value resistor did you end up using for the NFB resistor?  I'm guessing that using a DR OT that you are using an 8 ohm tap?
By the way, the clips are awesome.  Right up there with the best Dumble clips I've heard.
						First clips of the DumbleLite
Re: First clips of the DumbleLite
Thanks!Harris wrote:Norm, What value resistor did you end up using for the NFB resistor? I'm guessing that using a DR OT that you are using an 8 ohm tap?
 The NFB is a 6k2 off of the 8 Ohm tap (still using the 390R to ground).
