Peavey Donor amp build
Re: Peavey Donor amp build
You spelled "Donair" wrong.
				dcribbs1412
bcmatt wrote:You spelled "Donair" wrong.
can I even be taken serious now...
.dcribbs1412 wrote:bcmatt wrote:You spelled "Donair" wrong.oops
Well, not around sandwich fanatics anyways. Around here you should be ok.
				dcribbs1412
Thanks bcmatt
I have to get more time and give your blogs a look through.
Darin
Darin
Ya dumb sheet!bcmatt wrote:.dcribbs1412 wrote:bcmatt wrote:You spelled "Donair" wrong.oops
				dcribbs1412
Great...
Now Mark is givin me sheet...
Man I guy missples a cople wordz and wham...ruthless
Any way I have some more info/ideas and hope to get started soon...will update with any progress...and of course questions
Darin
Darin
Darin,
Keep the photos and progress notes coming always fun to see what people are doing.
				dcribbs1412
No problem Mark
Its helps me to upload stuff for others to see/check/make fun of etc... nice to go back later for reference...working at taking better/clearer pics.
Again just want to say I am very thankful to all for sharing their hard work and experiences. This forum along with it's members has given me knowledge and confidence to learn what I hope is a lifelong satisfying hobby/obsession.(blah blah blah...too sappy
Happy Holidays
Darin
Happy Holidays
Darin
				dcribbs1412
Here's the 1st mockup of what I hope will be a decent clean amp...(keyboards/steel guitar)
nothin new...low plate no OD into Fender reverb ..I might run the FET
off a relay maybe PAB also...if I can get the relay power setup right.
Thanks to Bob-I for showing me which direction to start in
Comments and suggestions are appreciated
Darin
http://i1018.photobucket.com/albums/af3 ... ean001.jpg
http://i1018.photobucket.com/albums/af3 ... ean002.jpg
http://i1018.photobucket.com/albums/af3 ... ean003.jpg
Darin
Where are you planning to locate the relays? You might consider moving the PS to allow the relays to go between the boards.
				dcribbs1412
Will do Bob...looking at pics of a build from another member here erwin_ve.Bob-I wrote:Where are you planning to locate the relays? You might consider moving the PS to allow the relays to go between the boards.
I'm thinking you mean something more like this...
https://tubeamparchive.com/download/file.php?id=11046
Darin
Yea, either way will work. Be careful to not cover the chassis mount bolt holes (how do I know about that... Trust me... I do)dcribbs1412 wrote:Will do Bob...looking at pics of a build from another member here erwin_ve.Bob-I wrote:Where are you planning to locate the relays? You might consider moving the PS to allow the relays to go between the boards.
Darin
You can see in my layout I took advantage of the chassis width and included the relays on the main board.
				dcribbs1412
Yes nice layout Bob thanks...ton of room in this chassis...kind of a shame I'm not using much of it with this simple build. At one time I had visions of the dreaded 3 S's type build...but brought myself back to reality.Bob-I wrote:Yea, either way will work. Be careful to not cover the chassis mount bolt holes (how do I know about that... Trust me... I do)dcribbs1412 wrote:Will do Bob...looking at pics of a build from another member here erwin_ve.Bob-I wrote:Where are you planning to locate the relays? You might consider moving the PS to allow the relays to go between the boards.
Darin
Darin
I almost screwed my relays with that chassis mount bolt, even with some room left, putting the screw in under a angle can have a unexpected resultBob-I wrote:Yea, either way will work. Be careful to not cover the chassis mount bolt holes (how do I know about that... Trust me... I do)dcribbs1412 wrote:Will do Bob...looking at pics of a build from another member here erwin_ve.Bob-I wrote:Where are you planning to locate the relays? You might consider moving the PS to allow the relays to go between the boards.
Darin
Darin:
If I had to do it again I also would move the main board to have some more room for the pots, this was a tight fit on that, doable but modding a tonestack would be a nightmare.
				dcribbs1412
Thanks erwin_veerwin_ve wrote:I almost screwed my relays with that chassis mount bolt, even with some room left, putting the screw in under a angle can have a unexpected resultBob-I wrote:Yea, either way will work. Be careful to not cover the chassis mount bolt holes (how do I know about that... Trust me... I do)dcribbs1412 wrote: Will do Bob...looking at pics of a build from another member here erwin_ve.
Darin
You can see in my layout I took advantage of the chassis width and included the relays on the main board.![]()
Darin:
I'm finding that this chassis even with all its room is challenging...
new mockup pic
http://i1018.photobucket.com/albums/af3 ... ean009.jpg
Darin
