Anyone do a Liverpool with Heyboers Lately???
hans-jörg
Re: Anyone do a Liverpool with Heyboers Lately???
Post by hans-jörg »
Be happy,
if your wife was´nt home you maybe destroyed something in the amp.
Put the cathodes of V5 and 6 on pin 3.
You are a lucky man. say thanks to your wife.
Hans-Jörg
ampmike
Thank You
Post by ampmike »
Thank you Hans,Tomorrow Im going to fire up with no tubes and check voltages,Talk To Ya Then,Mikey
ampmike
Problem
Post by ampmike »
On the Trainwreck Layout there is a red wire leaving V3 pin 5 going to V5 and hits R28 but is unclear what pin it hits,Cieratone does not show this,Any advise?
hans-jörg
Re: Problem
Post by hans-jörg »
ampmike wrote:On the Trainwreck Layout there is a red wire leaving V3 pin 5 going to V5 and hits R28 but is unclear what pin it hits,Cieratone does not show this,Any advise?
Hi,
this red wire is a mistake. Same as the black on V3 which goes like to pin 8 but it has to hit pin 9.
You have to think more logical through all.
A lot of stuff is like copy/paste, so there allways can be small mistakes. But the guys here expect that if you use their layout you know what you are doing. Its not the layout of a kit with resposibility of a company :wink:
The next: I saw that you put your output tubes pair next pair . The layout here has it i.e. V4, V5, V6, V7. You have it, compaired with the layout here: V4, V7, V5, V6. Do you understand?
Thats not a mistake, but its possibele that you compaire it the wron way with other layouts than yours. I did not check the Ceria Layout, maybe its there like yours. But than take care, whe you look at other layouts.
Allways count tehe Pins by yourself and write down at which pin what should be. As shown at the tube data sheet.
What I want say is: check every thing from both sides and dont trust only layouts.
Good luck
Hans-Jörg
Mikey you must know that pin 5 on all the tubes of this amp are filament pins so if you wired up all your filaments correctly pin 4-5 and 9 to V1-V3 and pins 4-5 of V4-V7 (EL84) your done with those.
Need to use the schematic more when building amps the layout is only a guide.
ampmike
TW
Post by ampmike »
Thanks Guys,Point taken about schematics.I guess I have to stop depending on chassis layouts I think in the long run they keep you from really learning.Thanx Again,Mikey
hans-jörg
Re: TW
Post by hans-jörg »
ampmike wrote:Thanks Guys,Point taken about schematics.I guess I have to stop depending on chassis layouts I think in the long run they keep you from really learning.Thanx Again,Mikey
Thats correct. I´m also a newby in amp building. But what I learnd is to double check with the schematic at least!
Hans-Jörg
ampmike
Liverpool fires up
Post by ampmike »
Hey Guys,My Liverpool is working.Need to put it in a cab with some sheilding.Its squeels a bit Middle and base seem to have a squeeling effect.But it feels good to have it done,Thanks Bob S.The 2 diodes being in wrong caused all the blowing fuses,Thanks for catching that.It definitley is more like an express for sure.High gain put this one mildly.I have to get it to quiet down a bit.Also did not see much difference in switching the bright switch.That needs a look at.Anyway thanks guys for all your help.As allways TAG is the best place to be building amps,And thank you rj for getting me all the parts Brother.Mikey :D
Bob S
Liverpool
Post by Bob S »
Congratulations Mike.
The beast can be tamed. Have fun.
Bob
Why Aye Man
RJ Guitars
Post by RJ Guitars »
Mikey,
If I recall correctly, this makes the hat trick complete, Express, Rocket, and Liverpool. Congrats, you are getting good at these... I can't wait to see what kind of cabinet you come up with for this. Looking forward to some of your soulful sound clips.
rj
http://www.rjguitars.net
hans-jörg
Re: Liverpool fires up
Post by hans-jörg »
ampmike wrote:Hey Guys,My Liverpool is working.Need to put it in a cab with some sheilding.Its squeels a bit Middle and base seem to have a squeeling effect.But it feels good to have it done,Thanks Bob S.The 2 diodes being in wrong caused all the blowing fuses,Thanks for catching that.It definitley is more like an express for sure.High gain put this one mildly.I have to get it to quiet down a bit.Also did not see much difference in switching the bright switch.That needs a look at.Anyway thanks guys for all your help.As allways TAG is the best place to be building amps,And thank you rj for getting me all the parts Brother.Mikey :D
Hi,
one more,
switching the bright depends from the position of the treble pot. If this is wide open the bright switch does not effect audible, at least maybe more hiss.
Hans-Jörg
