Favorite 2 tube preamp, 2 el84 amps?
Re: Favorite 2 tube preamp, 2 el84 amps?
EDIT:
I had posted the wrong info I will check the voltage on that Hammond AO-35 I know what the other Hammond organ transformer was 324v in my Hot Fudge with nuts build but forgot the voltages for the amp you asked about.
El_Martin
Post by El_Martin »
Hi!
What about the daisycutter?
http://ax84.com/static/daisycutter/18w_ ... 100422.jpg
If your in to the gainy side of life...
Ciao
Martin
Yes Randy Fay's Daisey Cutter amps sound good on youtube.
Deric
Post by Deric »
I built a DaisyCutter a while back and it's a great sounding amp. On the gainy side for sure...no real clean to be had but it sure is a ton of fun to play. Great master volume too.
Deric®
jcat5503
Post by jcat5503 »
El_Martin wrote:Hi!
Ciao
Martin
Yeah Randy is a great builder and designer, but I'm looking for something with a decent amount of headroom and a little chime..
surfsup
Post by surfsup »
What about the xitsamps x10 clone posted in the TW forum. The schematic has been updated with accurate values.
Andy Le Blanc
Post by Andy Le Blanc »
try out a watkins dominator
lazymaryamps
jcat5503
Post by jcat5503 »
surfsup wrote:What about the xitsamps x10 clone posted in the TW forum. The schematic has been updated with accurate values.
Oh yeah?? That sounds pretty sweet!! I'll try and find it.. Those things sound killer!
surfsup
Post by surfsup »
Zippy
Post by Zippy »
Did that thread ever conclude with a final schematic?
davesi
Post by davesi »
Modified Spitfire makes a nice compact amp. Sounds great. Recently did one in a PJ chasis. With good tubes, volume and cut are all you need.
Anything in moderation...nothing to excess
camerongrieve
Post by camerongrieve »
In regard to the modified Spitfire above, can someone explain if there's any benefit in having points C and D on the power supply (PI and pre-amp, respectively) at separate but parallel nodes, when they have the same dropping resistor and filter cap?
Couldn't that all be fed from the same point? Sorry if its a dumb question, just not sure if I'm missing something
ChrisM
Post by ChrisM »
camerongrieve wrote:In regard to the modified Spitfire above, can someone explain if there's any benefit in having points C and D on the power supply (PI and pre-amp, respectively) at separate but parallel nodes, when they have the same dropping resistor and filter cap?
If in series the resistor would drop more voltage. The voltage drop would be the sum of the resistance drawn by both tubes multiplied by the resistance.
But yes the same thing could have been done with one resistor to get the same voltage.
