I'm pretty darned happy with the amp after changing to the 12AT7. Early breakup, too much or farty bass doesn't seem to be a problem now. Originally, the power stage coupling caps were .1uf like the AA964. But rawnster and I changed them to .022uf to try to tame the bass a bit. However, now I wonder if I shouldn't change them back to .1uf to see what that sounds like.
greekie wrote:Atmospheric wrote:
With the voltages running as high as they are (505V across the first filter cap on Standby), I'm reluctant to go the SS recto route. I'd probably to have to get a new PT. In which case, I might as well just build another amp (which I may do at some point anyway). Even if I build another amp, I would still want to get this one functioning a bit better.
Just a side note - change the standby-switching so it mutes the amp instead of removing B+. Such an arrangement as yours is very bad for the rectifier tube as it sees a good bit of inrush current, and as you mention yourself, your capacitors go overspec on the voltage.
My point is: why take any of these risks?
Which speaker are you using? This plays a big part as well!
Also, perhaps change the type of phase inverter as well as the tubes to 6L6, so they get more juice.
YM2C
First, I don't really use the Standby - I keep it set On for the very reasons you mention. With a GZ34, the amp takes a good 40 seconds to fully warm up. AA964s don't have Standbys. This was just something extra we decided to add. You're right, we'd probably be better off without it.
Again, with the 12AT7, I think the amp (and speaker) does exactly what I want it to. I think it's now a matter of refining things.
As previously mentioned, I have tried 6L6s and I don't like how they sound as much as 6V6s. Also, I want to retain the cathodyne PI for now believing that it contributes a certain sweetness (when it's not misbehaving).
I really appreciate the help guys. Thanks again.
