I see. If fizziness is what i think it is my amp doesnt suffer from it but i'll give it a try. Thanks for the infoStructo wrote:No, the treble bleed is a high pass filter consisting of a .001-.002uF cap and a 500K trimmer that is put on the overdrive volume pot from the right hand lug to ground.
Then you adjust the trimmer to remove the desired amount of highs which help tame the fizziness.
Question about strange problem...
- turbo5speed
Re: Question about strange problem...
I know you said you can't do pics until after the weekend, but I think it's at the point where some hi-res pics and even some hi-quality audio clips would help tremendously.I see. If fizziness is what i think it is my amp doesnt suffer from it but i'll give it a try. Thanks for the info
Chris
This may sound dumb but you tried different speakers but did you try different guitars?
I had a LP that all of sudden started this strange overtone it was a cap causing the problem.
- turbo5speed
Yeah, i know. Going to do sound check in a couple of hours and maybe i'll ask the tech guy to do some recordings of this. Thank you.SoundPerf wrote:I know you said you can't do pics until after the weekend, but I think it's at the point where some hi-res pics and even some hi-quality audio clips would help tremendously.I see. If fizziness is what i think it is my amp doesnt suffer from it but i'll give it a try. Thanks for the info
- turbo5speed
I tried an LP and a Strat... same result i'm affraid.M Fowler wrote:This may sound dumb but you tried different speakers but did you try different guitars?
Thank you.
- guitardude57
Try checking component leads at their junction.......sometimes if you bend the leads too close to the part, they can get cracks.
Makes for some irritating noises.
Also look over all solder joints and reflow questionable ones.
I use a meter to test all solder joints for good continuity.
Hope this helps.
Mike
Hope this helps.
Mike
Mike
I am never surprised and always amazed
- turbo5speed
Hi.
While i prepare to gut my amp heres a little clip of last weekend gig. I dont know if the problem its perceptible but here goes anyway.
By the way... does it sound remotely like an ODS?
http://www.youtube.com/watch?v=1vUnTDTd ... r_embedded
Thx.
Thx.
I hear all kinds of poppin and fizzin but I really hope that is the camera mic and not the amp. If it was the amp that would have completely ruined that gig.
my 2 cents
my 2 cents
yeah, i'm pretty sure and hope that was the camera mic.
turbo...well your band sounds great and I was glad to have a listen, but when I mentioned "audio clip" i meant a close mic in a quiet room with hopefully a half decent recorder. Mess with different volume levels and channels to give us a good idea of the overall sound.
One positive thing, IMHO from what I can tell the amp is getting an ODS groove on.
Chris
- turbo5speed
Sould be the camera mic...T Wilcox wrote:I hear all kinds of poppin and fizzin but I really hope that is the camera mic and not the amp. If it was the amp that would have completely ruined that gig.
my 2 cents
- turbo5speed
Okaaaaaay... it turns out it was one of the power tubes. I measured the cathode current and one of the tubes was way off. Replaced the tube by a matched E34L, rebiased a little bit more hotter and also changed the g1 resistors from 5k1 to 6k8.
After rebias i got under 1mA difference between the two tubes so i got a pretty decent matched set.
I also measured the DC supply with my scope and i could see a fair amount of ripple (about 2Vac-pp) at iddle. I think i need more filtering... what do you guys think?
Problem solved! Thanks for all your help! I really appreciate it!
The band sounds great, really kick ass.
Glad you found the problem.
- turbo5speed
Thx mate!
I just suggest this as a last resort check.
I worked on an amp several years ago, and went thru it,...checked it out, and gave it back to it's owner. He came back about a week later and said it was still doing the same thing. I and several others in the shop tried and tried, but could not replicate the noise. As it turned out, it was the way the guy was picking. He could do it on just about anywhere on the guitar, so we finally decided it was his picking technique that was causing the buzz. You might have some other players see if this happens, and/or change the guitar you are using if you haven't tried that already.
a'doc
a'doc
Docampdoc1 wrote:I just suggest this as a last resort check.
a'doc
Interesting you should mention this..I had a customer come in and play one of his guitars through one of my amps and noticed a slight buzz in the background..He thought it was the amp since he didn't hear it on any of his....He swore there was nothing wrong with the guitar..Turned out to be slight fret buzz..Raised the bridge a few turns took care of it..You can hear everything on these amps..Especially the earlier ones without OD trigger
