TOO MUCH BASS
gary sanders
Re: TOO MUCH BASS
Post by gary sanders »
Im using much smaller filters than most do on these amps.2x 100uf.Still lookin around for a 250k pot.I'll put a guitar pot in there if i have to just to see if it helps.
dogears
Re: TOO MUCH BASS
Post by dogears »
Gary, the bass pot size has no effect on the actual bass. Pot is wired as a variable resistor so the only thing that changes is the setting. A 500K audio is just fine..... In fact, it is slower than the 250K linears that he also used. Save your attention for something else. This is not it.
Do you play on the bridge pup? Neck humbucker tone can be muddy with the Skyline config..... Bridge is perfect.
gary sanders wrote:Im using much smaller filters than most do on these amps.2x 100uf.Still lookin around for a 250k pot.I'll put a guitar pot in there if i have to just to see if it helps.
gary sanders
Re: TOO MUCH BASS
yes bridge mostly,on overdrive.I just piddled with the Duncan TSC and its showing me the difference in the .01 mid cap i have and the .047.I know its not accurate for the ODS but it does at least show a HUGE bass curve difference between the two caps so Im going to change that.
exocet
Re: TOO MUCH BASS
Post by exocet »
dogears wrote:Gary, the bass pot size has no effect on the actual bass. Pot is wired as a variable resistor so the only thing that changes is the setting. A 500K audio is just fine..... In fact, it is slower than the 250K linears that he also used. Save your attention for something else. This is not it.
Thanks for clearing that up Scott, I thought that that was the case with the bass pot as it is as you say wired as a variable resistor. I read somewhere that the TR CRS has a 1K between bass pot and ground, rather than the skyliner config which has 10K, does this make much difference to bass response?
greiswig
Re: TOO MUCH BASS
Post by greiswig »
ampdork wrote: The 30uF's may not be helping...
I'm confused...can someone explain the effect of the filter caps on the bass? Big caps make it tighter...looser...bigger...??
-g
erwin_ve
Re: TOO MUCH BASS
Post by erwin_ve »
Bigger filter caps make the low end more tight.
Drumslinger
Re: TOO MUCH BASS
Post by Drumslinger »
erwin,
like from 30uF to 100uF?
erwin_ve
Re: TOO MUCH BASS
Post by erwin_ve »
Drumslinger wrote:erwin,
yes. Also when filter caps are in series for each node, like a bluesmaster, the overall response is reacting faster.
