Komet, Trainwreck "Songwriter"
- FUCHSAUDIO
Re: Komet, Trainwreck "Songwriter"
That's cute, but not the one I recall. There was one Standell amp that had dedicated high and low preamp stages (filtered high and low), and a volume control for each (acting as low and high controls) and then a common master. They acted as bass and treble controls and worked pretty nicely. Forget the model, but always wanted to noodle with that circuit at some point.
You probably mean something like this...
[img:800:593]http://i211.photobucket.com/albums/bb13 ... ematic.jpg[/img]
I'm not really sure this is where Ken aimed at when he developed the songwriter though. I'm guessing it's something much less complex.
- FUCHSAUDIO
Even thought I don't think that's the topology Ken used, it does look like and interesting circuit.
Hi, I can't seem to make out the cap value between the 270k anode and the 150k on the Bass control. Any help please. Thanks.
- guitardude57
Hi, Could someone show me how to wire the input resistors for a single input on the Standel 25L15 clone from riscado's above post? Thank you.
Really....? That preamp can't be right can it? Without a load resistor at pins 3/7, and then looking at the 12AU7 PI, how could this amp have enough gain be gig-able? Too, look at the power supply filtering at point 'D' - how odd is that, 44uf? I think something is amiss here.
Has anybody built this?
The 12AX7 grids are sharing a 100k grid resistor. The PI seems to be set up more for a 12AX7 but you see lots of 12AU7 circuits like that.
The Standels were supposed to be clean amps, squeaky clean; and this circuit looks like it would produce plenty of gain to drive those sensitive 15" JBL's...
TT
TT
I am just interested in the unusual tone controls. I have a Clubman clone and I would like to try it. Thanks.[/i]
