Likewise Jelle! Sweet PCBs!jelle wrote:Ultra, the sheer beauty of your builds are an inspiration. Thanks for that.
Welagen ODS with PCBs
- UltraHookedOnPhonix
Re: Welagen ODS with PCBs
See if the attachments works for you. That PS board is the one I've used since 1999, and if you print the power point document you can use it as a template to drill a clad board. Use the gif files to draw the traces with a Sharpie. I built many an amp that way!mlp-mx6 wrote:Will you be making any of these boards available? In particular the PS and relay boards?
For the relay boards, maybe the attached files (which are somewhat unrefined) will help you a bit as well.
Good luck,
Gil
txbluesboy
Stunning build quality!
