I know all about my friends build because we were copying one 18W amp and trying to get the same sound as much as possible... in the "orig" version all resistors inside were MOX 2W. I have recommended in the new one to put all low noise MF to the input valve V1 EF86..only to get better signal/noise ratio..R.G. wrote: ↑Thu Feb 23, 2023 1:14 am Great! I'm glad he was happy with his work.
Unfortunately for the question at hand, his attestation that it was a great improvement is what's called "anecdotal evidence". An anecdote is of substantially no value in proving that something is or is not. This is because people can see and hear things that they just make up inside their heads, and hear them different ways.
This is not to say that he does not hear it as better. He almost certainly does. But does that mean everyone would think it was great? Almost certainly no. So one anecdote is worth about zero at proving things like this. Actually, a thousand anecdotes are worth the same as one anecdote.
Did he make any other changes in his amp while "improving" it?
There is a human bias to think our own work is amazingly good. It's subtle, and all we can do is be aware that we think anything we do while "improving" something is a step in the right direction. And if we believe our bias, it is completely true - inside our own head, but not necessarily outside in the real world.
He has finished started the amp, played for a week or two, but reporting some extra "presence" in the sound all the time..voltages were the same in both amps. He was chasing familiar tone, amp which he already had, and playing for many years, and was easy to detect tone of the new amp that is not like that.
So he started to change the differences, MF resistor -> MOX in the first valve cathode EF86.. with that he has killed some amount of the highs and called me that sound lost extra presence and after i was playing that amp too.. so something happened with the highs with that material change.
Did dale just pass all the sound without filtering? Did MOX resistor act like a some very small LP filter and remove some highs that was possible to detect with ears? And why acted like that? Something happened.
This is just one example, i'm experiencing it every day.. so for me there is no doubt, last decade i started to look in the guitar amps tone cooking like a gastronomy, sauce cooking..not anymore like a electrical engineering thing
Then this is about the resistors, if we add capacitors in the formula ...
