Excellent, thanks! I just so happen to have 33K/2W resistors handymartin manning wrote:Each pot has one lug connected to a lead from the rectifier board (purple in the layout drawing), and also a 15k resistor from another lug going to ground. The 33k resistor goes across those two lugs, which will put it in parallel with the pot's element. 100k in parallel with 33k is 24.8k. The third lug is the wiper, which is where the bias voltage is taken from.
Dumble - help needed urgently!
Mousey Dung
Re: Dumble - help needed urgently!
Mousey Dung
I let the amp stay on in case the bias needed to settle a bit. There was no howl, but a very, very slight hum.martin manning wrote:Determine a target reading for the meter: Estimate the loaded plate voltage at say 95% of the unloaded value, 0.95 * 440 = 420. 6V6GT are rated at 12W max plate dissipation, and we'll choose a bias point at 70% of that, or 0.7*12W/420V = 0.020 A. This is a conservative value since you will be measuring cathode current which includes the screen current. The target 0.020 A will be indicated as 0.020V (20 mV) on the meter since you are measuring the voltage drop across a 1-ohm resistor.
Plate voltage (as measured from node 1 of the output board): 450 V
450 * 0.95 = 427.5;
0.7 x 12W/432.25 = 19.65
So I ensured that none of the voltage at the four test points exceeded 19.65 mV and this was the result:
V8: 18.2 V
V7: 19.6
V6: 19.6
V7: 18.6
Sounds like you're doing great. Are you getting sound out? I mean, did you plug your guitar in?
Mousey Dung
No, I didn't. Was being careful! Can I go ahead and try it out now???xtian wrote:Sounds like you're doing great. Are you getting sound out? I mean, did you plug your guitar in?
Mousey Dung
I guess I need to work on those trims on the preamp board now. Any recommendations on how to proceed? There are eight in total!
Yeah, man, you've got it powered up, voltages checked out, bias set...play it!
Mousey Dung
Everything seemed to be fine, guitar signal was coming through, until I engaged the OD switch in the back, at which point there was a loud howl. So I turned down the volume low and hit the switch again. At low volumes there was no signal whatsoever from my guitar coming through, just a hum. What could be causing that?
As Martin mentioned in the biasing instructions, try reversing the wires (blue and brown?) from the OT that go to the power tubes.
Mousey Dung
OK, wasn't sure that that was applicable, since it works fine without me hitting the OD switch in the back panel?drew wrote:As Martin mentioned in the biasing instructions, try reversing the wires (blue and brown?) from the OT that go to the power tubes.
If it works fine in clean mode, then that indicates that the power amp is working fine.
It seems the issue is in the OD channel side of things. Can you scope it? If not, and time is a factor, find someone whio can put a sinewave on it, and scope it. This will save you a lot of time.
Also, is there a layout for this amp?
Mousey Dung
It's the clean that is having problems. When the OD switch is on, I can use the overdrive section - the drive and level knobs work in conjunction with the volume level.
However, when I flip the OD to off position, that's when the hum-and-no-signal problem starts. In that hum mode, when I turn down the master volume, I hear a mechanical rattling inside the amp -- could it be the relays?
No idea. But did you read my post?
Layout - see 2nd to last post on thread page 2
Mousey Dung
Yes, I did. Although it's the drive channel that seems to be okay and the clean channel that is having problems. I just tried it again, in clean-sound mode, with the standby switch in off position turning down the master volume, at which point the rattling begins. Really sounds like it's the middle relay.jelle wrote:No idea. But did you read my post?
There is a diagram on page 2 of this thread. That's all that I (and everyone else here) have available to work with.
Is it possible that you have the blue wire from the master volume pot that is drawn as passing underneath the middle relay, actually *connected* to the relay, other than at the point where the wire terminates?
