So you're saying that if Allyn had called it a "Welded aluminum box chassis" with the dimensionsHogy wrote:A plain, undrilled aluminum box is no infringement, but as Pete points out, you called it a "Komet chassis".
Hogy
19.25" X 7.25" X 2.50"
.125 thick aluminum!
Corner welded brackets.
All sides welded.
Undrilled and Unmachined
That we wouldn't be having this conversation?
This seems like an awfull lot of Bu11sh1t for a poor choice of words! And what does Komboking have to do with it? Why would you email him? He was simply making a box! He has no control over what Allyn calls it!
This whole thing is because Allyn used the term "Komet Chassis" and when he changes it.....you complain! He's damned if he does and damned if he doesn't! He only changed it to placate you. Not to make your replies look like nonsense!Hogy wrote:You have four times now edited your original post and its title so that my replies seem to make no sense, and that's your idea of a respectful discussion?
Hogy
Maybe we should refrain from using the term "Komet" here alltogether?!
 It seems one of the minions has come here to stir things up a bit. Since we agreed not to post schematics and layouts, I think that is not an issue. I don't remember sending Ted weber a copy of anything lately. Maybe you should visit
