FENDER 5F4???
FENDER 5F4???
SORRY FOR MY ENGLISH, I HAVE A BIG CONFUSION,THE SUPER 5F4 HAVE A VERY INUSUAL CONECTION IN THE PLATE AND SCREEN,THIS IS TRIODE CONECTION OR NOT? IF NOT,WHATS IS THIS?THE SCREEN IS FIRST AND THE PLATE AFTER,FOR MY THIS NO LOGICAL,PLEASE,A EXPLANATION IS VERY APRECIATE,THANKS VERY MUCH
						Re: FENDER 5F4???
Here is what Ceriatone is doing with it.
				collinsamps
Re: FENDER 5F4???
I'm not exactly sure what is confusing you, but the way Nik connected the OT centertap to pin 4 of the second socket looks more confusing than it actually is.   The screens and OT centertap on the original layout are tied to the same point as the 2nd choke wire is at the filter capacitor.   Meaning that both are powered by the same voltage so it doesn't matter, his way will work, but looks funny going to pin4 on both sockets and then from the last socket to the OT CT.
						Re: FENDER 5F4???
Craig,
I'm not sure if we helped this guy out or not no response.
				collinsamps
Re: FENDER 5F4???
I lived in Europe for 12 years and flew in & out of there for 20............me either.
						Re: FENDER 5F4???
Are you (Mirlo02) looking inside an amp, or basing it on a schematic.
Also, other than the OT CT wire going to V5 instead of V4, the Ceriatone doesn't appear that much different. I'm new at reading layouts ... did I miss something?
									"A man with an experience is never at the mercy of a man with an argument." Hilmar von Campe
						Re: FENDER 5F4???
server error
						Re: FENDER 5F4???
server error
						Re: FENDER 5F4???
Same thing electrically.
The CT just goes to V5 instead of V4.
I also notice that Nik has the primary wires reversed from the original.
Re: FENDER 5F4???
Some fender tweed amps did this (5E1, 5F2, 5E8A are the same). It puts the screens a couple of volts higher than the plates at idle but that doesn't matter much. Stick a 1k-4k7 5W resistor from the 'screen node' cap to the screens if that bothers you (It didn't bother Leo at the time)mirlo02 wrote:SORRY FOR MY ENGLISH, I HAVE A BIG CONFUSION,THE SUPER 5F4 HAVE A VERY INUSUAL CONECTION IN THE PLATE AND SCREEN,THIS IS TRIODE CONECTION OR NOT? IF NOT,WHATS IS THIS?THE SCREEN IS FIRST AND THE PLATE AFTER,FOR MY THIS NO LOGICAL,PLEASE,A EXPLANATION IS VERY APRECIATE,THANKS VERY MUCH
Re: FENDER 5F4???
thanks very much,now is more clear
