Dumb-Lator pcboards please check
Did some work today.
Would you please check if they are OK.
Henk
Henk
									Dutch hand build amps
						Re: Dumb-Lator pcboards please check
I traced all the way through it and did not find any errors. Good Work.
www.RedPlateAmps.com
Very nice, thanks for sharing. One small observation, I remember from a previous post that the higher voltages should go to the cathode follower
They way he has it works betterdimitris wrote:Very nice, thanks for sharing. One small observation, I remember from a previous post that the higher voltages should go to the cathode follower
I'm sure you know better.I will try it this way when I will build mine.Thanks heisthl.
Thanks a lot Heisthl,heisthl wrote:I traced all the way through it and did not find any errors. Good Work.
On my Printer "Samsung CLP-610D" Kodak Premium High Gloss Photo Paper works best. Need some more work to peel off. Result is very
sharp edges. Try some other Brands for the best result on your own Laserprinter. I know Epson Premium worked best on a HP 1100 Monochroom Printer and is easy to peel of.
Henk
Hi Henk<
Looks nice! What's the choice of your transformer?
Thanks a lot Erwin,erwin_ve wrote:Hi Henk<
I use prim. 220/230 V - 30mA -> Sec. 220 V - bridged. 6.3V-1A
They are custom made by Jaspers Transformatoren in Maastricht.
I use them in every Preamp 1 to 3 x 12AX7.
 kijk in je PM
 kijk in je PMHenk
						- mdroberts1243
Thanks for doing this!
I've been sitting with a bag of parts for a D-lator forever and this spurs the project along.
-mark.
My tube blog & link directory: http://tubenexus.com
Cause & Effect Pedals FET Dream and Dumble Style Chassis
Hi,
thanx a lot!
btw, how must the psu be changed to use a sec. 220V transformer?
hmm, do I see the soldering side? The black pic I mean, cus the green one is the same with the componets on.
Greetz
						thanx a lot!
Greetz
Very nice work thank you for this.
I haven't done PCB building for years but this I may try.
