Heater voltage measurement
				briango2000
For the 6.3 VAC on the heaters...I should be measuring across both pins that the heaters are wired to?
						Re: Heater voltage measurement
Correct.
The centre-tap of the transformer heater winding is tied to ground, so if you keep your black multimeter lead clipped to the chassis as you'd normally do then each of the heater pins should read 3.15Vac relative to ground, or 6.3Vac between the two pins.
Just be careful when using two hands inside the amp to measure across two pins. It's best to have the amp in standby mode to do this, with the B+ caps discharged, although there are still healthy voltages floating around at the power supply end of the chassis.
Paul
Paul
