Hello,
I have a harmony/valco 18 watt amp that I recently rebuilt.  After getting it going, I find the tremolo to be a bit anemic.
I was wondering if somebody could suggest the cap and or resistor value to increase it's depth.
Here is a link to download the schematic:
http://www.mediafire.com/?j9jstxmjwmn
regards---Ron
						Help Tweaking Tremolo Depth
Re: Help Tweaking Tremolo Depth
How much did you rebuild? The values in the trem circuit are pretty common, and pretty much optimised. Replace the .01 and .02s with new 1KV caps; have a strong tube as the oscillator; replace the bypass cap on that tube, too. If that doesn't do the trick, holler back.
