Insulated pots?
arfy
Insulated pots?
Post by arfy »
This is going to be my first experience with an aluminum chassis and also with a high gain amp.
My question is, if I'm running a ground buss wire across the back of the pots and grounding the cathodes to it, don't I need to use insulated pots? As far as I can figure it would create a ground loop otherwise. But maybe I'm not getting it.
Any comments or experiences?
paulruby
Re: Insulated pots?
Post by paulruby »
Don't insulate them. Think of them as one big single connection to the chassis. Provided you don't connect your circuit ground to the chassis anywhere else, this will work fine.
FYI: http://paulamps.com/info.html#Ground
