Single Ended project phasing out?
Basic AX84 SEL (single ended lead) amp.
I have built one of these, and it works great.
I just finished another one, but there is a problem.
It works ok with Gain2, but when I try to use Gain one, the volume goes away and disappears as I increase it. Needles to say, it only has about half the gain it should have.
I have looked and scratched and measured...and put it away for the moment. I swapped preamp tubes in and out, and even tried the power tube.
Any ideas?
The schematic is at AX84.com, Classic Projects, SEL Amp.
I don't know how to insert an image in PHPbb boards.
[/url]http://www.ax84.com/sel/TEMPORARY_LINK_ ... 080729.pdf
Any ideas?
Re: Single Ended project phasing out?
Ignore the link I tried to post...
the pdf of the schematic is attached.
I suppose what gets me is...how can it pass signal through the first gain stage into the second, but disappear as I increase the volume on the first stage?
Tube 101...is the first gain stage being driven into cutoff?
Or, another small possibilty...the filament current is bled out?
I guess I need to hook up the meter to see if either of these conditions exist.
The obvious way (to me) would be to have a reverse taper pot or the pot wiring incorrect. Assuming I understand the problem that is.
I would check the wiring to that pot. You can also bypass the pot as a test. That would really narrow it down.
I would post over on AX84 also. Some of that crew post over here so they might chime in.
Pete
Pete
Thanks, fishy.
I miss Arizona!
Jump off the pot?
I stared at this until my eyes were popping.
It's gotta be something really dumb.
Reverse taper sounds just about crazy enough to check.
I'll get back to you.
I miss Arizona!
Jump off the pot?
Potentiometer direction is the same on both.
So that's a negative on the reverse taper theory.
If its not a reverse taper or a pot wired as such, I am not sure I understand the problem. It does sound like it is working backwards from your description.
Got a camera you can take a picy with so an extra set of eyes can take a look?
It's wired according to the attached schematic.
As far as I can tell, that is.
Having some trouble with the new camera (why does it need to load software for this PC to "see it").
It sounds like you're getting some oscillation robbing the power. You'll need to find the source, which can be a pain without a scope. Post some pictures of the lead dress.
Well, I studied the schematic and layout. traced out voltages with the meter, and got some intermittent oddity around the coupling cap between stage
2 and stage 3.
That was it!
I replaced that cap (it was a brand new one, tested ok on the meter...),
and life is grand.
Passive testing of capacitors is kind of a gambler's territory.
It sounds good, even better than the first SEL I built.
2 and stage 3.
That was it!
and life is grand.
Sweet...... always feels good to get something working properly.
I've thought about making one of these at some point. First thing I ever did was an HO for my lad. That was when I got hooked on this as a hobby.
Haven't been the same since...
As with most of the AX84 projects, it's ok as a building block.
With a bit of thinking and tweaking, a person can build a great amp around these designs.
