Did KF switch around the heaters wire in the otput section ?
eg there is a pick of francesca where it seens that on the power tubes he has swaped wires form v5 to v4 he has reversed the wires ?
i'll try and get the picture up bud i downlowded it from this site.
is this possable or am i just seeing things?
heater
Re: heater
Yes, you will see the heater wires out of phase. Allynmey has tried it both ways– in phase and out of phase– and it doesn't seem to make a difference.Pongo316 wrote: Did KF switch around the heaters wire in the output section ?
Tim
Re: heater
Thanks I'm new to this TW stuff ?
And thought I was seeing things.
On with the build
On with the build
Re: heater
You'll look at those picture so much as you build that you will see LOTS of things that aren't therePongo316 wrote: ... And thought I was seeing things...
Good Luck
Tim
