I am the proud owner of an Ecofan Super Audion MK3 - EL34 PP amp, input valves ECC88 type (actually PCC189's), phase split valves 6cg7's. The amp builder ( Murray Dick ) is now deceased.
It was originally all transformer coupled, but after a swap of the input stage from 12v valves to ECC88 type, it now has one stage of capacitor coupling from the input buffers to the phase splitter valves.
I want to swap out these coupling caps for some posh ones, but im not sure which ones are the coupling caps.
So, gutshots -
Two pics of the area where the input valves connect to the phase splitters ( i replaced the phase split valve sockets myself, so its MY horrible soldering not Murrays )
The orange non polarized caps leading to a resistor leading to the pin are .47uf - are these the coupling caps?
Also, i think there are some electrolytics that are swollen/leaking -
Is that what a "swollen to the point of leaking electrolyte" cap looks like?
And one more total beginner question - on a diagram of a valve pinout, is the numbering with the valve pins facing towards you, or away from you?
thanks in adv
