Hum only at max
sluckey
Re: Hum only at max
Post by sluckey »
You put your NFB switch right next to the input jack! THAT'S A HUGE NONO!!! Move that switch to the back panel or just eliminate it. Then try to clean up your grounds.
Re: Hum only at max
Post by Stevem »
Also check where that feedback wire goes.
Getting a hum on that when you probe around should not be.
Do you possibly have it connected to that gain stages grid and not the cathode as it should be?
audiosalvage
Re: Hum only at max
Post by audiosalvage »
I removed the NF switch for now and put a switchable cathode cap mod in its place, moved the bias resistor so it's not crowded. Amp is quiet and stable throughout the pot ranges. I might just live with that. Thanks Gents.
