Hello all,
I would like to build an AB763 2-6L6 style power amp section only with a 1/4” input.
Maybe with a Super Reverb OT.
I know the Power Amp Section begins at the .001uF Coupling Cap entering the PI.
Does anybody know of or have a layout to correctly add Input Jack and Volume Control and anything that needs to be adjusted ?
Thanks for any help and advise
						AB763 Style Power Amp Layout ?
Re: AB763 Style Power Amp Layout ?
Here's mine...
Oh wow thank you!
Regarding my initial post, I misinformed about Super Reverb OT (2 ohm), SR was in my brain, just planning 2-6L6 - Multi-Tap OT or just 8 Ohms.
That schematic looks great!
The main value changes I see are the .1 > .047 PI to Power Coupling Caps -- and -- 220 > 1R Grid Leak Resistors
For Power Section only build like this, do you recommend to keep these adjusted values from original?
Planning to go with 2 6L6 if any difference..
Thanks again
Thanks again
It's popular to use .047 rather than .1 coupling caps for a tighter bass sound. You do not need to replace the 220K grid leaks, especially with a 1R resistor!
Fender's smaller 2x6L6 amps used 10K and 10K power supply droppers while the larger 2x6L6 amps used 1K and 4.7K droppers. I would use 1K and 4.7K for a 40 watt (or greater) size amp.
No, the 1R are bias sense resistors.
