geetarpicker wrote:I probably the minority to believe an attenuator with a Wreck is my prefered way to tame it down.  I usually prefer a THD over my Airbrake. It seems the Airbrake is brighter than the THD and that is something that the Wrecks really don't need any more of.
As much as a smaller powered amp make sense, it seems that once you have smaller iron the low end just isn't the same...
I think a big part of the "feel" with a Wreck is the power supply sag, something that doesn't happen with a master volume.  I also wonder if a power scaling circuit can emulate that effect?  The sag in the power supply IMHO helps the amp to compress when pushed, but open back up when backed off.  In performance this evens out the volume and allows the amp to go from "clean to scream" with very little actual volume change.  At least that's my take on it.  Maybe power scaling can capture this sag effect?  It seems all the masters I've heard really hurt the clean headroom in relation to the dirty volume.
I remember Ken Fischer mentioning a response he heard from Eric Johnson about playing a Liverpool back in the day.  Apparently Eric said it was the "best practice amp he had ever played", as in not loud enough for his stage use.   That said these days Eric does have tinnitus, though I heard he is back to 100s for his lead tone after going to smaller amps for a while.  Maybe he wears earplugs these days?
Hi Glen
You start right off by saying "my preferred way"... that's the point in the end really, what works for you works for you, and that's a good thing.
I only had a brief expirience with the scaled amps but the sag didn't seem to be affected. Personally, I think any addition, to any amp, changes something, my question is always "can it be compensated for and is it worth the trouble?"  Also, the powerscaling isn't really a typical master volume, and like everything else there are a bunch of ways to implement it and, like everything else, there'd be a learning curve to sorting it all out. I'm still only considering it myself, I'm not decided in which way I'm going to go as of yet.
The tinnitus issue I think could be taken more seriously by some folks, I sure wish I had of.  I played loud myself for a lot of years, and did sound professionally for some time also, I now have a pretty serious case of tinnitus in my left ear, and it really, really sucks. But, I'm still a guitar player too, and I was and am a real tone whore, it's gotta be all there or don't bother, and a lot of amps, like the TW, come to life cranked, it's just the way it is. My deluxe was like that, although it wasn't super loud, but my Garnet session man was, and so was the marshalls... the quest for me now is a good way, whichever way that is, to be able to have a fundamental controll over the output without sacrificing tone to the point where it can't be fixed or compensated for. Attenuators are one way, lower power is another way, and I've looked at powerscaling and a few other methods for output power controll as well. At the very least, they are worth trying.
I still like "loud", but "controll" is a good word too.
Glen, BTW, your clips kick ass. They are partly responsible for me picking up the guitar again.
