Ive scrounged what appears to be an old wheelchair lift
its 26"x26" and is .125 aluminum
and the tax fairy left a 36" metal brake
it looks like I can get a couple chassis out of it
2"H x 7"W x 22"L
the last few years I've scraped up a marshall 100w opt
a pt from an old 200w tubed PA head that ran 4 6550
and this winter, got lucky, and ended up with an old floor moniter
that held a JBL E120-8 in mint shape
the published information for the OPT
is making it look like Ill be able to use an 8 ohm load
on the 4 ohm secondary and end up with an effective load resistance
close to the published RCA and GE values
It should develope 60 to 80 watts when biased to a modest 50%
of max plate dissapation dependending on the voltage conditions
acheived by the power supply
so my load is pretty well defined
Ill follow up with numbers after a bit
but I still have questions:
what would be the best application for the speaker?
open cabinet or closed cabinet?
I like a combo but with the weight as an issue Im leaning
toward a closed and seprate cab
any opinions on current production 6550's?
I love NOS but want to use the new
whats your favorite phase inverter?
Ill need to make 40 to 65V (rms) to drive the 6550s
AB for desired output watts.
old wheelchair lift
Andy Le Blanc
old wheelchair lift
lazymaryamps
