I am collecting parts and schematics and ideas, i d like to keep it close to the original with just a few modification.
It is going to be a solid state rectifier and this is the only real difference.
I have few parts from a fender champion 600 but this is not mandatory.
I d like to use the same power transformer, it looks like it could be right for the job, specs are:
cp 600 230v
Ip 230v 50hz
Op 275v 6.3v
If i use this one i need to stick to ss rectifier.
Or i can purchase this one: Power: 88VA
Input: 220-230-240V
Output:
- 270-0-270V - 0.12A
- 6.3V C.T. - 2A
- 5V - 2A
But i d like to keep it ss rectified. Is there a schematic for a 5f1 champ without the usual tube rectifier?
The output transformer is also not yet decided.
I could use the champion 600 one but it is to small and not very good in terms of quality. I can always replace it later.
I will only but a bypass switch on the negative feedback and apart form this, not other changes will be made.
Cabinet will be solid pine and custom made by me, i m a woodworker so no problems there
Speaker will be a 4ohm, 10 inches, it s a warehouse veterans, which i already have and it is waiting for a small tube amp to fit in.
I have the chassis and and i have no problem working on metal too.
Any help will be very appreciated.
I m just starting with this project.
