AB763 grounding scheme
Fender Amp Discussion
corkhead
Post by corkhead »
Hi all,
I will soon be launching into a Mojotone DR kit, and looking for a definitive guide in improving the stock grounding scheme. OR, talk me out of it, and tell me why the original is just fine!
I have read a LOT of posts about brass plates, copper buss bars etc, but the is no step by step or well documented path. If anyone can weigh in, I would be grateful. Thanks
Roe
Re: AB763 grounding scheme
Post by Roe »
the problem is not just bad grounding but that most of the preamp shares one filter cap, while the reverb shares a cap with the screens
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Here is is how I modified the AB763 grounding for a Deluxe Reverb: https://ampgarage.com/forum/viewtopic.p ... 77#p428877 No brass plate, no ground bus.
ViperDoc
Post by ViperDoc »
Roe wrote: Wed Jun 01, 2022 6:42 am the problem is not just bad grounding but that most of the preamp shares one filter cap, while the reverb shares a cap with the screens
I'm working up a Super Reverb AB763. I see the reverb driver is powered by the screen cap as you mentioned. If you were to run a "second B node" just for the reverb driver, would you need a 22uF cap, or could you lower it to 10 uF, say? I plan to run individual 22 uF for each preamp tube, and I'm going to incorporate Sluckey's tremonator.
Just plug it in, man.
Roe
Post by Roe »
ViperDoc wrote: Wed Jun 01, 2022 6:06 pm
it depends. If you use 1k between the nodes, I'd try at 33-47uf.
4x12" w/H75s
corkhead
Post by corkhead »
martin manning wrote: Wed Jun 01, 2022 8:02 am Here is is how I modified the AB763 grounding for a Deluxe Reverb: https://ampgarage.com/forum/viewtopic.p ... 77#p428877 No brass plate, no ground bus.
I have pored over this thread and the accompanying picture for quite some time, and I am still unclear. Which is why I asked if there is a step by step guide or a definitive well documented path.
pdf64
Post by pdf64 »
The notes on the photo may initially seem a bit cryptic, but if read alongside the DR AB763 schematic, may eventually make sense.
https://el34world.com/charts/Schematics ... _ab763.pdf
eg BC- refers to the negative terminals of the B and C node caps of the HT supply, as per the labels on the schematic.
https://ampgarage.com/forum/download/fi ... &mode=view
In the light of that, is there anything you’re still stuck on?
I've added a marked-up layout to the first post in the DR Replica thread.
corkhead
Post by corkhead »
martin manning wrote: Sun Jun 05, 2022 1:28 pm I've added a marked-up layout to the first post in the DR Replica thread.
Thank you very much! I will pore over it and hopefully my aged and rusty neurons will wake up, and it all makes sense.
Did you notice and improvement over the original AB763 wired as per the schematic?
I can't help but think replacing the input signal wires from the jacks to the pre-amp tubes with shielded wire grounded at only one end will further lower the noise floor at idle.
corkhead wrote: Tue Jun 07, 2022 4:44 amDid you notice and improvement over the original AB763 wired as per the schematic?
If I had built an identical amp with the original grounding I could answer ;^) I can say that the amp as built with the new scheme is very quiet.
corkhead wrote: Tue Jun 07, 2022 4:44 amI can't help but think replacing the input signal wires from the jacks to the pre-amp tubes with shielded wire grounded at only one end will further lower the noise floor at idle.
Wouldn't hurt, may or may not make a noticeable improvement. To do the inputs right would require moving the grid resistors to the sockets, and then I'd probably want to ditch the low input. In the end I left it original, no problems.
Roe
Post by Roe »
you need a filter cap and ground for each of the 6 preamp tubes (pluss screens and mains)
4x12" w/H75s
corkhead
Post by corkhead »
Roe wrote: Tue Jun 07, 2022 1:25 pm you need a filter cap and ground for each of the 6 preamp tubes (pluss screens and mains)
Why? Surely the filtered B+ (point D in links to schematic posted above) voltage has already benefitted from a choke and 2 dropping resistors prior to it. The ripple if any would be tiny?
It's not just the ripple voltage; decoupling of the stages is also important. The last filter is powering no less than six triodes, where two or at most three is usually considered the best practice. It's not quite as bad as it seems, though. Typically only one channel is in use at a time, so the worst case is it supplies four active triodes, and the phase relationship of the reverb recover stage to the others is all over the map. I find there are no issues with the one I built, and in fact the original circuit design and layout, random grounding and all, has been working pretty well for almost 60 years :^)
corkhead
Post by corkhead »
martin manning wrote: Thu Jun 09, 2022 10:32 am It's not just the ripple voltage; decoupling of the stages is also important. The last filter is powering no less than six triodes, where two or at most three is usually considered the best practice. It's not quite as bad as it seems, though. Typically only one channel is in use at a time, so the worst case is it supplies four active triodes, and the phase relationship of the reverb recover stage to the others is all over the map. I find there are no issues with the one I built, and in fact the original circuit design and layout, random grounding and all, has been working pretty well for almost 60 years :^)
Thanks Martin. My understanding is from the way the choke, 2 resistors and 3 capacitors are configured they form 3 consecutive low pass filters (B, C and D), successively dropping the voltage and further smoothing out AC ripple. Are you suggesting adding (say, 2) additional 16uF 450V electrolytics at the common high voltage junctions of the 100k screen resistors of the 7025 preamp stages, further adding to the effective capacitance to ground at node D?
If so, how would that be different from changing the electrolytic at node D to say 50uF?
And how can we decouple DC? Maybe I am thinking too much, or (more likely) don't understand the subtleties of AC to DC filter stages and the effects of loading them.
If you can point me to an online resource that can shed light on this mystery I would be most appreciative!
I am just looking to build a nice and quiet clone, using best practice from the current era, whilst staying true to the high tide mark of sonic design that this amp represents (IMHO).
Thanks in advance...
Roe
Post by Roe »
corkhead wrote: Thu Jun 09, 2022 2:14 am
its bad practice to let many preamp tubes share a filter cap and to have a messy ground path (and to power the reverb from the screens). Rebuild and decrease noise/hum. it works
4x12" w/H75s
