Is This Wiring Correct??
zozoe
Post by zozoe »
Greetings,,, From the revised drawing I've attached, is this right in that I'll have 2 mono ins (for independent amps for stereo), and that the Series option will work only if i insert a bypass at the blue 'X', to disconnect any contact between the 2 speakers?
thnx
​​​​​​​[attachment=0]Screenshot_20220602-221925_Gallery.jpg[/attachment]
https://linksharing.samsungcloud.com/8s9xo2UA6iAF
Re: Is This Wiring Correct??
Post by Stevem »
Yes, that will work once you insert a high current switch to open or close where you have the X.
Do not use a mini toggle switch!
For example a 100 watt amp would need a switch rated for a minimum of 5 amps.
pdf64
Post by pdf64 »
The + to - link between the speakers needs to be broken if the L and R jacks are used.
It may be a problem to have amps connected to all 3 jacks, or the 16ohm and L or R, at the same time, even if they’re not powered up.
zozoe
Post by zozoe »
STEVEM, Cool, & what about for only 20-30 watt amps... what amp value switch would be ideal?
Thnx
