Dumble Bargain
ijedouglas
Re: Dumble Bargain
Post by ijedouglas »
Anyone notice the larger (3A?) diode in the bias circuit? I wonder if that was done for tone? I know there has been a discussion regarding diode type (fast/soft...) having an impact on the tone.
Ian
Re: Dumble Bargain
Most people believe solid-state rectifiers sound different from vacuum, but in cases where solid state and vacuum are compared in the same amp, the difference is has been found to be minimal if anode voltage and bias setting are controlled. Differences between solid state rectifiers of the same type (or current rating in the same type) are likely to be extremely small, and in the case of push-pull output sections will tend to be cancelled in the output transformer. I don't see debate around solid state rectifiers in a quick search, other than the noise reduction potential of fast recovery diodes.
ijedouglas
Re: Dumble Bargain
So if there is no impact to the tone/sound/feel of the amp, why would he have put a different diode in that position?
Ian
Re: Dumble Bargain
Who knows? Why use a high current diode in a low current (bias supply) application? Some Hi-Fi types have claimed different brands of tube rectifiers have different sound, but I'm not aware of any such claims around high-current solid state rectifiers.
ijedouglas
Re: Dumble Bargain
I would love to know. I have not heard a difference between 3A and 1A diodes but I can definitely hear a difference between standard (1N4007) and fast recovery diodes. I can also hear a difference in the resistors in the bias circuit so maybe HAD could hear/feel something with that diode. I highly doubt he would just randomly use a larger diode in that position.
I happened to be watching this and it piqued my interest:
Ian
Re: Dumble Bargain
What part of the 1:32:24 was it that piqued your interest?
ijedouglas
Re: Dumble Bargain
The 3A diode in the bias supply
Ian
talbany
Re: Dumble Bargain
Post by talbany »
ijedouglas wrote: Sat Mar 19, 2022 11:42 pm I would love to know. I have not heard a difference between 3A and 1A diodes but I can definitely hear a difference between standard (1N4007) and fast recovery diodes. I can also hear a difference in the resistors in the bias circuit so maybe HAD could hear/feel something with that diode. I highly doubt he would just randomly use a larger diode in that position.
The video is disabled??
Dumble also used this diode STK-9010 1000V 3A in the Silver Alligator in the mains bank and 1N4007's in the bias?
This is what I've found on FRED's
https://ampgarage.com/forum/viewtopic.p ... es#p408589
ijedouglas
Re: Dumble Bargain
talbany wrote: Sun Mar 20, 2022 1:35 am The video is disabled??
Yeah, just click on it and it will take you to YouTube.
I think the link you provided that was the discussion I was referring to. Any idea why he would use a 3A over a 1A when they are both way over spec'd for the job at hand?
Ian
talbany
Re: Dumble Bargain
Post by talbany »
No
Re: Dumble Bargain
ijedouglas wrote: Sun Mar 20, 2022 12:57 amThe 3A diode in the bias supply
I thought you meant there was something specific about rectifiers in that YouTube that drew your attention to the bias diode.
talbany wrote: Sun Mar 20, 2022 8:10 am
No
HAD seems to have used replacement parts that were available from local electronics shops, or possibly from surplus shops. Maybe it was just something he had lying around, and he put it in that important location thinking that it would probably never fail?
Fast recovery diodes are required for high-speed operation in SMPS, typically 500-1000x higher than the 60-120Hz in a linear power supply. No reason not to use them at low frequency in pursuit of noise reduction, unless you are a volume manufacturer trying to pinch pennies. Here is a trace showing the reverse-bias switching transient: https://ampgarage.com/forum/viewtopic.p ... 6&p=187281 At low current, the reverse flow isn't visible at all at 100 Hz, very obvious at 10 kHz.
Max
Re: Dumble Bargain
Post by Max »
talbany wrote: Thu Mar 17, 2022 7:33 am ... (Caps say 1976) ... I was dating the amp (using the most recent cap date as a reference) ...
" ... FULL RIVER CAP.CO.,LTD (MIEC) was established in 1979, more than 40 years experiences in this area, we specialize in producing aluminum electronic capacitor, major products are middle and high voltage capacitor, MIEC is able to provide fast, flexible and innovative approaches to meet the needs of the market. ..." https://www.miec-cap.com/index/index.php
ijedouglas
Re: Dumble Bargain
Max wrote: Mon Mar 21, 2022 1:02 pm
Based on the listing description, the amp was brought back to HAD after he bought it in 1988 to have the tremolo circuit installed. HAD also seemed to use the MIEC caps in later (5th gen on) amps. I don't think we should be trying to date the amp based on those MIEC caps :D The TVAs do seem to be original though.
Ian
Max
Re: Dumble Bargain
Post by Max »
And what exactly do you mean by "original" in this context?
ijedouglas
Re: Dumble Bargain
Max wrote: Mon Mar 21, 2022 4:24 pm And what exactly do you mean by "original"?
"original" would mean originally installed in the amp when it was built. Pure conjecture but a good chance don't ya think?
Ian
