BURN IN
ViperDoc
BURN IN
Post by ViperDoc »
What is the "right way" to burn in an amplifier? I find a litany of conjecture on the topic. Do you leave a chassis on for 24-48 hours? With tubes and a load or without? On a variac?
Much appreciated as always.
Just plug it in, man.
pompeiisneaks
Site Admin
Re: BURN IN
Post by pompeiisneaks »
I don't know if there's a 'right' way. Some people just play it for a bit over a few days and it's burned in that way, others play music through it for a day or two. Etc...
Some run a frequency through it into a dummy load... some do nothing.... :)
ViperDoc
Re: BURN IN
Post by ViperDoc »
Thanks for the ideas.
wpaulvogel
Re: BURN IN
Post by wpaulvogel »
Play the hell out of it!
ViperDoc
Re: BURN IN
Post by ViperDoc »
Indeed! It’s true, the 5E3 that I play with my American rock band is the most broken-in amp that I’ve made, go figure. I wondered what y’all do when road-tripping a new build is not in the cards. Those other methods, however, can’t be nearly as fun!
TUBEDUDE
Re: BURN IN
Post by TUBEDUDE »
After all testing, I play the hell out of it over a week while leaving it on for the first 48 hrs with hourly monitoring of the AC current draw, temperature, and the power tube plate current.
wpaulvogel
Re: BURN IN
You don’t need to leave it on.
TUBEDUDE
Re: BURN IN
Post by TUBEDUDE »
Have to monitor cabinet temperature. My designs are not like the usual. Tight enclosures, each different, so complete testing is required
mhuss
Re: BURN IN
Post by mhuss »
You can say that again - very cool enclosures. :D
