Jim,
Last thing...these amps need to be pretty loud IMHO to open up so bear that in mind
M
Hello Jimteleman1 wrote: ↑Tue May 18, 2021 3:35 pm Cool, do you have the exact lay out of that dumble ,? I liked how with all that gain which i dont use that much gain but when the treble tone pot was opened up it still had that tele bite , i wish there were more audio clips of that dumble with a tele !! Take care and thanks for getting back , Jim Weider
3rd generation "pre-classic" clips: (Posted By Max)3rd generation made around the 1978-1979 Ser# around 60-75..
Since these alterations occurred around a 2 year time frame and more than 1 or 2 amps and for the sake of accuracy should be referenced as 3rd generation ODS and shouldn't be looked upon as tweaks or custom voicing s for a certain customer..
Changes are listed on the top right of the layout are
https://ampgarage.com/forum/viewtopic.p ... 61#p140261
1 Treble: 250KA treble pot
2..005 soldered between the wiper and top of the Bass pot
3.Black RG59/U 75 ohm foam - similar looking as the Tandy Wire RG59/U 75 ohm foam in ODS #094,(see below picture) but without the "Tandy Wire" label
Although this layout wasn't taken from an actual 3rd generation specimen perhaps I'll run across one here in the future..If so I'll make another separate layout better reflect the accuracy's of that amp (3rd Generation)
Tonyhttps://tubeamparchive.com/viewtopic.ph ... 117#135117
https://tubeamparchive.com/viewtopic.ph ... 120#135120
https://tubeamparchive.com/viewtopic.ph ... 121#135121
Clean sound of a 3rd generation "pre-classic" Overdrive Special 50W combo with 12" Altec 417-8H Series II with a paper dust cap mod
Karl Ratzer "I Fall In Love Too Easily"
Karl Ratzer – guitar
Karl Hodina - accordion
Don't miss Karl Hodina playing his accordion!
More discussion
https://tubeamparchive.com/viewtopic.ph ... 428#138428
Hey Max," "Village Feeling" starting around 18 " is perhaps the best example I have heard of the 3rd gen amp. I wish I had heard this before now, and this has inspired me to listen to more of his material. Thank you for sharing thisMax wrote: ↑Fri Mar 19, 2021 1:28 pmAFAIR he used his Fender Nocaster for this track and his 3rd generation ODS 50WX Combo (hardwood cabinet similar to the late 70ies early eighties Boogie hardwood cabinets). AFAIR the speaker in this cabinet at the time of this recording was an Altec 417-8H SERIES II. The original metal dust cap had been replaced by a paper dust cap. You can get some glimpses of this combo on this video (No Nocaster). "Village Feeling" starting around 18:00. Have fun!
Max
Great tone! I think I had that song on repeat for about a month while I was building my 3rd Gen
It's a great reference for sure!ijedouglas wrote: ↑Wed May 15, 2024 1:42 pmGreat tone! I think I had that song on repeat for about a month while I was building my 3rd Gen![]()
