Measurements are done with Focusrite Scarlett 2i2 with Arta and measurement test point is send connector on the loop.
Here is the measurements with Bright switch OFF, Rock ON, Deep ON, OD and Boost OFF.
First treble pot, bottom line position min, then 9 o'clock, 12, 3 and max, all other TS pots are at 12.
Then mid pot, bottom line position min, then 9 o'clock, 12, 3 and max, all other TS pots are at 12.
Then bass pot, bottom line position min, then 9 o'clock, 12, 3 and max, all other TS pots are at 12.
Now the measurements with Bright switch OFF, Jazz ON, Deep ON, OD and Boost OFF.
First treble, bottom line position min, then 9 o'clock, 12, 3 and max, all other TS pots are at 12.
What I can see from the above pictures, there is no big change in the FR measurements when you pass 12 o'clock on the TS pots, on Rock settings.
On the Jazz settings situation is little better.
Is this normal behavior of the TS pots on Dumble ODS?
