6505 mods
				Jackstraw89
6505 mods
So I recently came into possession of a 6505 combo. It’s not working. So a tech friend and I are gonna have to crack it open anyway. While we’re in there I was thinking we could mod the clean channel to something a bit more interesting. I’ve heard Soldano has a great clean circuit, as does Dumble. But does anyone else have any thoughts?
				sluckey
                                            6 others liked this
		Re: 6505 mods
Fix it as is before you do any mods.
Re: 6505 mods
These amps typically blow out output tubes which then in turn open up the screen resistors and blow the V+ fuse.
Be sure to look at the tube socket solder connections to that output tube board while you have it out and are replacing those 470 ohm screen resistors.
