Bluesmaster PT
Vertigo
Bluesmaster PT
Post by Vertigo »
When building a 6l6 Bluesmaster, what primary voltage should be used for the PT? I'd like to try to snag a ClassicTone before they're gone. A schematic I found lists a 320V primary but that schematic doesn't match Tony's layout and I'm skeptical. I can't seem to find reliable information on the Magic Parts PT in the layout but I did see somewhere in another forum that it's 345V.
thank you
Sean Chaney
Re: Bluesmaster PT
Heyboer makes something close to TF-130, but better. See: https://ampgarage.com/forum/viewtopic.p ... 54#p149554 Scroll down a bit for the schematic diagram. They can make one for you if you give them the part number.
professormudd
Re: Bluesmaster PT
Post by professormudd »
My HRM Bluesmaster build has a classic tone 40-18029.
-Matt
It may very well be that the sole purpose of your life is only to serve as a warning to others.
Vertigo
Re: Bluesmaster PT
Post by Vertigo »
professormudd wrote: Sat Nov 21, 2020 2:08 pm My HRM Bluesmaster build has a classic tone 40-18029.
interesting, which primary did you use?
Sean Chaney
professormudd
Re: Bluesmaster PT
Vertigo wrote: Sat Nov 21, 2020 4:23 pm
First I tried the red 710v primary, but plate voltage was sitting at over 505v without a load. So on the advice of the kind folks here I switched to the red/white 610v, and got the plate voltage down to 405v. It works great, though I have no basis for comparison.
-Matt
norburybrook
Re: Bluesmaster PT
Post by norburybrook »
professormudd wrote: Sun Nov 22, 2020 1:52 pm
505v without a load would seem correct though no? with a load that will drop. My bluesmaster is running at 500v with a load :D sounds great :D
405v seems a bit low for an ODS.
M
professormudd
Re: Bluesmaster PT
norburybrook wrote: Sun Nov 22, 2020 3:20 pm
M
This was guidance given from xtian in the technical discussion... Maybe one day I'll switch it back and see how she runs. But as of now it's good. I neglected to mention, and I'm sure it makes a difference, but mines a 44 watt.
-Matt
norburybrook
Re: Bluesmaster PT
professormudd wrote: Sun Nov 22, 2020 4:27 pm
M
Ah not 6L6'/El34s then? that makes a big difference :D
Sorry I thought it was regular amp.
M
professormudd
Re: Bluesmaster PT
norburybrook wrote: Sun Nov 22, 2020 5:40 pm Ah not 6L6'/El34s then? that makes a big difference :D
M
I find that EL34s give my amps an English accent.
Mine runs 2 6L6
-Matt
norburybrook
Re: Bluesmaster PT
professormudd wrote: Sun Nov 22, 2020 5:57 pm
M
Mine runs 2 6L6
LOL..... :mrgreen:
well 6L6's are quite happy with up 500vDC I've found. The amps I've made from old Peavey Transformers all run around 500vDc on the plates.
give it a go, you might like it :)
M
