Merlin's Practical Serial Effects Loop layout
wattsup
Re: Merlin's Practical Serial Effects Loop layout
Post by wattsup »
xtian wrote: Thu Oct 25, 2018 5:01 pm
wattsup wrote: Thu Oct 25, 2018 4:06 pm I want to try this. If I were going to put a control pot on the return, would I put a 1M pot in place of the 1M resistor, or put a coupling cap after the 100K resistor and then a 1M or something like that value going to the phase inverter?
Just replace 1M with pot. To me, this is unnecessary, because the Send level control covers that base.
Thanks xtian. You answered my other question as well.
raveonstevie
Post by raveonstevie »
Sorry for the necro bump but this seems like the best place to ask.
Is it best to use switching jacks so the signal can continue to flow through when there are no cables plugged in to the send and return?
dorrisant
Post by dorrisant »
The Return jack only would be a closing jack.
That's typically the way it's done. A non-switching jack is used for the send so the signal can be tapped there without interrupting the connection to the return jack's switching contact. When something is plugged into the return, the connection to the send tip is opened.
raveonstevie
Thank you!
raveonstevie
Yep. I see now. Thanks
